Problems opening d7d
Juho Könnö
Posted on 27.07.2012 13:08
Hi all,
I'm trying to open d7d files on a Linux system with the C API. Opening the file gives a file corrupt error, if I just omit this and try to read the file I can see the channels correctly etc. but no data and the sample rate, duration etc. are stored incorrectly. Could this be a compatibility issue between different operating systems in the recording device and the server I'm running the code in? The files open without a problem in Dewesoft.
Below a sample output:
[code]DW Version = 2000300
FILE INF: sample rate = 0.000000Hz, start store time = -39189976561262246970430725607562200076821754744082620271352507639809740052856435115531959297151777119987459994818486215297208693186561385357192894138240584872186924957315631701735923843122528856766690304202700467272938570289566992227676784925809799041532371440888712002387404756399987071264608241054906318848.000000days, duration = -1003196993065516417420228274725311683418410650487528812813562729611451337312888044819100831516928461042409824446178308407400509282510060619945607723788664623130158399151540832502823370500028482802131181628482324615809421446231094433972843458969774766145078754627551232.000000sec
CHANNELS:
Name=Moment Unit=v Description=
Name=Current 2/AVE Unit=V Description=
DATA:
Channel=Moment Sample count=0 Array size=1
Channel=Current 2/AVE Sample count=0 Array size=1[/code]
Br,
Juho
signup
for
free
account
