DWDataReader - Reading full speed data
Hey there,
I'm attempting to use DWDataReader with MATLAB to import .dxd files. I've followed the example script and was able to import data with the DWGetScaledSamples function, but I noticed that the channels get read at their own sample rate. I know within DeweSoft it is possible to export all channels at the highest sample rate, and channels with a lower rate will simply get upsampled so that everything is synchronized. Is it also possible to do this with the DWDataReader in MATLAB?
Thanks!
a function that would do that is currently not present in the DWDataReader. We've received a request for this recently and it's been added to the wish list. You'll also be notified if it gets implemented.
The feature request however has a pretty low priority, because the same functionality can be implemented on the user side, and therefore it's mostly a convenience function.
