DCOM Access is only working on 64 Bit machines ?
i made i small test appliaction with Visual Studio2017 community by using C#. I used it with DEWOSOFT X2SP10 as well on 64 bit and 32 Bit machine.
It:
- Reads current version
- Reads current active Settup
- Reads Name of current Data File used
The problem is:
On 32 Bit machine, i only reveive the Version Number. Current Setup and current Data File returns nothing. Same Solution runs on 64 Bit Systems without any fault.
Question is, why the baviour is different on 32 and 64 Bit ?
Thanks in Advance
Marc
I've attached the examples that we've discussed via the email.
I was able to create a working example by using an old Windows XP machine with Visual Studio 2005.
All running fine on XP :-).
Problem is:
I was not able to create a working example by using Windows 7,32Bit.
The same error as before regardless the DEWESOFT Main Version, or Build ,i use.
Can you please provide a working example with Windows 7,32 Bit ?
Thanks in advance
