C++ Plugin Read data from a measurement channel.
Please provide an example of how to find and read data from a Dewesoft measurement channel and then output it on a plugin channel in a C++ plugin. Below are snippets of my code. I started with the C++ Dewesoft tutorial that shows how to mount channels and I am now attempting to read channels and output that back out via the plugin.
IData* data;
_bstr_t MyChannelName = "amb_temp";
data->FindChannel(MyChannelName, &foundChannel);
foundChannel->GetValueAtAbsPos(-1,NULL,TRUE,&tempValue);
ch3->AddAsyncSingleSample(tempValue, time);
pluginGroup->MountChannel(7, TRUE, -1, &ch3);
_bstr_t s3 = "Amb Temp C";
ch3->put_Name(s3);
ch3->put_Used(TRUE);
thanks!
we already have some examples on our webpage which you should look at. If you have Visual Studio 2015, then you should use the extension wizard: http://www.dewesoft.com/download?file=DewesoftX2Ex...
To find other examples, just search the developers section. Please note that you have to be logged on in order to see the files.
The general principles of reading data are described in the DCOM manual, available here: https://www.dewesoft.com/assets/dcom/dws7_dc_how_t...
Thanks for the reply. I am currently using VS 2013. I was able to read a channel in the following way:
float tempValue;
double tempValueScaled;
IData* data;
long dPos;
IChannel* dirBufPos;
app->get_Data(&data);
foundChannel->get_DBPos(&dPos);
foundChannel->GetValueAtAbsPos(dPos - 1, &dPos, TRUE, &tempValue); //Works, but is not scaled
foundChannel->ScaleValueDouble(tempValue, &tempValueScaled);
