Resistance measurement
Brian Balvin
Posted on 12.04.2023 23:26
I am trying to measure resistance between two points, in my case a "switch", in order to trigger once a specific resistance level is met across the switch. With only two wires from my switch, I am having trouble wiring this as an analog input. Initially, I thought simply wiring my switch in series between IN- and IN+, or between IN+ and EXC+, but neither seems to work. Hardware is a 43V, and sensor/switch is an OEM customer part, with target resistance levels in the rage of 1000-4500 ohms. Any guidance or suggestions?
Edit: we are currently doing this manually with a typical digital multimeter, so I am basically trying to replicate the ability of the multimeter's resistance measurement mode.
Primoz Lapi
Posted on 17.04.2023 09:41
DEWE-43 doesn't support resistance measurement directly, but you can use DSI RTD adapter.
ersin basaran
Posted on 31.10.2023 15:31
I have same issue with Iolite, 6xSTG... It seems Iolite stg supports resistance measurement, however, i can't figure out the connection diagram on the channel setup.
Rok Kmetič
Posted on 03.11.2023 14:11
Dear Ersin,
the dotted lines are optional connections that you can make and the bold ones are necessary. On the picture below is an example of how to connect a resistor to the STG amplifier:
Below you can see the connection diagram explained:
I hope this helps.
Best Regards,
Rok
Sam Daniel
Posted on 05.12.2025 13:46
I’ve run into this before - for resistance measurements with Dewesoft, you pretty much need to use a proper shunt or a dedicated bridge setup. The AI-modules don’t measure resistance directly, so feeding a known current and measuring the voltage drop is the usual workaround. Once you set up the shunt and scale it in Dewesoft, the readings stay pretty stable.
