modal analysis
losting dove
Posted on 17.04.2025 06:43
I am currently using Dewesoft X3 SP2 for a vibration analysis experiment. I have simultaneously acquired signals from two accelerometers, and now I want to calculate the phase difference between these two signals at a specific frequency.
I have already tried the following steps:
Added two accelerometer channels in the channel setup.
Added an FFT analysis module in the math section and selected these two channels as inputs.
I configured the relevant parameters in the FFT settings, such as the window type and frequency range.
However, I cannot find a direct function to calculate the phase difference between the two signals. I checked the FFT result channels and only see the magnitude and phase spectrum for each individual signal.
Is there a direct function in Dewesoft X3 to calculate the phase difference between two signals? Or are there alternative methods to achieve this?
I would like to display the phase difference as a function of frequency in a graph.
My Dewesoft hardware is a Sirius HS. The operating system is Windows 10.
Thanks!
Rok Kmetič
Posted on 18.04.2025 12:51
Dear losting dove,
We have an article that describes calculating the time delay between two signals using Correlation math: https://support.dewesoft.com/a/solutions/articles/14000086629?lang=en
Please let us know if this is useful for you.
Best Regards.
Rok
