Wiring for laser sensor , Tachometer
Pieter Dekker
Posted on 20.01.2020 14:51
I'm trying to get a RPM reading using a Monarch Tachometer ROLS-P . How do i wire the sensor to the 7-pin digital input of a DEWE43?
I have attached the datasheet. 'Monarch-ROLS-1071-4851-113.pdf '
Pin Assigment is
tip = signal
middle = +V
base = drain.
Posted on 22.01.2020 09:29
Dear Pieter,
Thank you for your question. Tachometer should be connected on counter connector. I assume this should work properly.
tip = signal pin 1
middle = +V pin 6 +12V
base = drain. pin 7
Kind Regards,
Matic Pevec
signup
for
free
account
