Wiring diagrams for analog sensors pressure and temperature
Pieter Dekker
Posted on 20.01.2020 14:38
I am trying to connect a absolute pressure sensor to the analog input pin connector on the DEWE 43. The pressure sensor has a 4 pin M12 male connector with a 0- 5 V voltage output. I am unable to figure out how to connect the sensor to the 9 pin D-sub female connector on the DEWE 43 for analog inputs. I've been through the DEWE 43 manual which contains the different types of sensor connections and schematics, but I am unable to identify which would be the most suitable for this particular sensor.
Do the schematics on page 22 and 23 imply that i need to use twisted pair cable? I have attached the spec sheet for the pressure sensor see 'WebTec-MPT-BU-ENG-2406'. The 4 pin M12 male connector has the following schematic: For pins 1 to 4
1 : V IN
2: V OUT
3: GND
4: N/C
I have a similar sensor to connect temperature see datasheet ' WebTec-TP125-BU-ENG-1764 .pdf' pin assignment is
1; +IN
2; V OUT
3; GND
4; CASE.
How do i wire up to 9pin dsub on dewe 43?
Posted on 22.01.2020 09:20
Dear Pieter,
Thank you for your question. Shielded cable is needed in harsh measurement environments where is a chance of signal interruptions.
MPT-BU-ENG-2406 - pressure
1: V IN - pin 5 +12V. Supply voltage of sensor is 10 - 30 VDC
2: V OUT - pin 2 IN+
3: GND - pin 4
4: N/C
TP125-BU-ENG-1764 - temperature
1; +IN - pin 5 +12V. Required supply of sensor is 12 - 32VDC. If directly supply from DSUB is not enough you should provide external supply.
2; V OUT - pin 2 IN+
3; GND - pin 4
4; CASE - pin 4
Kind regards
Matic Pevec
