Using excitation voltage from DEWE-43a for Honeywell pressure sensor that uses only 3.3V?
  • Dewesoft Instruments
  • Using excitation voltage from DEWE-43a for Honeywell pressure sensor that uses only 3.3V?
Hugo Lehoux
Posted on 04.08.2023 14:53
In my research lab, we recently bought a Honeywell ABP2DRRT001PDAA3XX (https://cz.mouser.com/ProductDetail/Honeywell/ABP2DRRT001PDAA3XX?qs=ljCeji4nMDmtNzy%252B%2Fo3xmg%3D%3D - I am attaching the manual) that requires 3.3V (min. 3V, max. 3.6V) DC for power supply. Looking at the DEWE-43a manual and several answers on this forum, I see that its excitation voltage is fixed at +/- 5V, which is too much for our Honeywell sensor. I was wondering if this was always true? And, if there actually is a way to change the excitation voltage of the DEWE-43a, could you please provide it to me?
I have been thinking of using resistors to reduce this excitation voltage to 3.3V, do you think that would be a viable solution?
Thank you in advance for your assistance.
Hugo
Rok Kmetič
Posted on 07.08.2023 16:21
Dear Hugo,
as you already figured out the excitation on DEWE-43 is fixed and cannot be changed. There is no other way to lower the voltage without an external circuit.
You can use the mentioned solution with resistors or use a 3.3V voltage regulator. For example https://eu.mouser.com/ProductDetail/STMicroelectronics/L78L33ABZ-AP?qs=7IaIRco65plqHZGvVBuyKw%3D%3D
Just be sure to choose the correct one that will withstand the current required for the sensor.
Best Regards,
Rok
Hugo Lehoux
Posted on 07.08.2023 17:43
Dear Rok,
Thank you very much for your fast response, very much appreciated! I will definitely look up voltage regulators and try to find one we could use in our setup. Thank you for the help, have a great day.
Hugo
