Please help me understand the SIRIUS amplifier types: STG, STGM, STGM+, etc
Lemmy Atom
Posted on 24.02.2021 22:05
I'm trying to explain to my collogues the different SIRIUS "STG" variants. Literature is gets confusing with all the options
This is what I've come up with:
STG (voltage, full/half/quarter bridge strain, current, resistance, temperature, potentiometer)
STG+ (same as STG but with counters- think encoders. etc)
STGM (same as STG but without the temp and potentiometer I think)
STGM+ (the “+” is just a counter input option useful if you do any encoder stuff)
STGS (?)
MULTI (same as STGM but with Digital inputs and analog outputs) Multi channels can be split to utilize inputs and outputs simultaneously (?)
Please correct me and add additional details.
Thank you.
Posted on 25.02.2021 17:01
Hello Lemmy,
+ refers to counters, stg, acc, lv etc. with + means that counter digital inputs are implemented.
STGM don't supports Resistance measurement and needs DSI RTD for RTD temperature measurements.
On the left you see STG on the right is the STGM, you find the data on our page.
STGS is not part of dual core family of Sirius amplifiers but is part of HD (high density amplifiers) which are even more limited because they are operating with limited ranges
in comparison with dual core with has 2 active ranges.
Multi is STGM with Counter and Analog out combined in one amplifier.
I recommend you to check the Sirius manual for further informations.
Matjaž
John Yaron
Posted on 17.09.2021 21:10
Does the MULTI Analog-Output signal support the capabilities provided by the DewesoftX Function Generator?
John Yaron
Posted on 25.09.2021 03:42
Primoz Lapi
Posted on 15.03.2022 10:32
the analog out on Multi module has the same capabilities as the one on the back of the Sirius.
If there is a Function generator license, it will work.
