Lorenz Torquemeter wiring to DEWE 43 A
Axier Bollar
Posted on 11.06.2021 10:01
Good morning,
I need some help in which could be the best wiring solution for a 4 wire Lorenz torquemeter with +-10V analog output.
Attached you can find the datasheet.
Thanks a lot for your help in advance.
Axier
Rok Kmetič
Posted on 16.06.2021 09:07
Dear Axier,
first, I want to apologize for the late response.
I have checked the specifications of the sensor and can confirm the Dewe-43A is suitable for this torque sensor.
In the picture below I have marked how to connect the sensor wires to the DSUB9 connector:
The Dewe-43A has a sensor power supply (12V, total limit 350 mA) shared between: 8xAI, 8xCounters, 2xCAN.
If you require any further information, feel free to contact us.
Best Regards.
Rok
Axier Bollar
Posted on 16.06.2021 11:24
Dear Rok,
Thanks a lot for your response.
Just a little question. Should I make a bridge between 1-6 and 3-8 in the DSub9?
Thanks and best regards,
Rok Kmetič
Posted on 16.06.2021 13:20
Dear Axier,
sorry for the missing detail. Dewe-43A has also a sensor excitation ±5V. It is mostly used for bridge measurements.
There is no bridge needed, the pins (1-6 and 3-8 on the DSUB9) can be left unconnected.
Best Regards.
Rok
