Krypton technical manual
Is there any documentation available on the Krypton LV type (10kHz)?
More specific: how many units (4LV) can be used in combination when measuring all channels at 10kHz samplerate?
Thanks,
Harm
Senior Software Engineer
Hi Harm,
currently there is still no manual for Krypton LV. But to answer your question, from my experience number of Krypton-LV can depend on quality of ethernet card. On tests we ran 10xLV8 @ 10khz with no problems, with exception of one broadcom card where it worked with only 5 of them. 4 channel LVs will work at least as good, if I had to guess, I would say you should be able to connect 50% more compare to LV8 (so 15 in total) and still be ok.
David
Hi Harm,
There is recently a KRYPTON manual added in the section SUPPORT / DOWNLOAD / MANUALS (Dated: 23.11.2015)
Andries
