DS Tacho1 Supply Voltage
Stefan Jaik
Posted on 13.08.2019 08:05
DS-Tacho1 is a nice hardware for inductive sensor signal conditioning and we want to use it also with counter inputs from other vendors.
Must the supply voltage on Lemo PIN5 (see attachment) be exactly 5V or is there a tolerance?
The measurement system we want to use has only one global supply voltage an we need to set it to 10V (to supply pressure sensors)
- so do we have to use a DC/DC converter for the DS-Tacho1 to work?
Rok Kmetič
Posted on 13.08.2019 09:59
Dear Stefan,
the 10V global supply voltage won't be a problem, because the Tacho1 has a wide max input voltage range.
All data about the Tacho1 can be found in in the manual which is on our page.
Best regards.
Stefan Jaik
Posted on 13.08.2019 10:19
Hello Rok,
the speed sensor is conectet to the DS-Tacho1 via the Sub-D input and that's not what i asked.
I want tho know what's the max. tolerable supply voltage (it comes from the measurement system on Lemo PIN5)
for the DS-Tachos internal electronic circuit.
I can't find data about this in the DS-Tacho1 manual, just the picture i've attached above..
Stefan Jaik
Posted on 23.08.2019 14:04
just to complete this topic: the max. supply voltage is 5,5V
Posted on 26.08.2019 09:24
Dear Stefan,
Yes, you are correct.
Internal electronic circuit component(s) lowest absolute maximum rating is rated at 5.50V. This is in term defines the maximum DS-TACHO1 power supply rating as mentioned coming from the system on LEMO pin5 to 5.50Vdc in reference to GND on pin7.
Regards
