Current Measurement in Serial Line
I want to measure leakage current on the vehicle by using the 50 ohm shunt resistor of my sirius lv device. However, when i did serial connection from positive line of the vehicle, and measure it with the sirius lv current measurement wtih shunt, i see different values between dewewsoft and standart multimeter. What could be the reason ? Am i making a wrong connection ? Do i need to use an external shunt resistor ? Can you please help about the issue ?
Regards,
Berkan
Dear Berkan,
we would need additional information, so we can support you with this issue.
How is everything connected? Can you provide a connection diagram?
How did you set the channel in DewesoftX?
An LV amplifier requires an external shunt resistor to measure current:
For a better understanding below is an explanation of how the sensor is connected to the device:
Best regards.
Rok
Dear Rok,
You can find the connection which i tried to do in below picture.
Except this connection, i tried to do without shunt resistance with the current measurement option of LV channel ( though it has a shunt internal in lv connector. ) But still i cant measure correct value.
Dear Berkan,
did you set the shunt correctly?
From the provided picture I noticed that you have a 0,4 Ohm shunt.
Set the External shunt to ''Custom'' and insert the values of the shunt resistor:
Dear Rok,
Yes i set it correctly. Could the LV channel be preventing the completion of the circuit ?
Dear Berkan,
in the previous post, you mentioned that you see different values between Dewesoft and standard multimeter.
How big is the difference?
There is also a possibility that the multimeter is showing wrong values...
