Analogue output issues with SIRIUS
Dear Dewesoft,
I am generating an analogue output from a SIRIUS. The shape of the output signal is determined by a function I define in a math channel.
However, I noticed that if I connect a voltage tester to any channel, even if I don't generate anything, I have an output of a few mV, which is undesired in my case.
In addition, this also happens sometimes when I generate a 0V output.
Do you know what can cause this? Thanks.
Regards,
Emanuele
Dear Emanuele,
could you please provide a data file so we can see if this is a normal behaviour or it's something else causing this issue.
Regards
Dear Dewesoft,
I will provide a data file, but the SIRIUS outputs about 20-30 mV even if the software is not running, I just saw this using a tester. Is this value within the uncertainty of the instrument?
Emanuele
Dear Emanuele,
we talked with our hardware developers, and this is their answer:
typical offset results at factory calibration is less than 5mV for 20kS/s and 80kS/s. Specified limit is 20mV.
Only 2% of measurements that passed are above 5mV.
Values above specified limit 20mV are not within the uncertainty of the instrument. Please return the unit for check and calibration.
Regards
