Import channels (triggered acquisition)
So here's my situation: I make at least 2 measurements (one after another) to verify test repeatability. Then I import the channels from my 2nd recording for analysis with my 1st, which allowed me to compare two graphs from different recordings.
The measurements were done manually (i.e clicking on "Record"). To make my life easier, I set up a trigger condition to start and stop recording. However, by doing so Dewesoft fails to import the channels. It says that it is unable to open file at first, and when it does open it on the 2nd attempt, an "Access violation" error popped up.
My question is so : Is this normal? Can Dewesoft import trigged recordings?
Ps- attached the debug report from my attempts
Dear Andrew,
We have tried to replicate the error but weren't able with our setup. Import worked also on triggered data files. Can you please share the setup that you have used and if possible also the data files. You can upload the data on the private forum or send it to [email protected] if you would like to keep it private.
Best reagrds,
Primoz
Dear Primoz,
I have sent an email with the download link to [email protected]. Thanks for looking into the matter
Andrew
