How shall we connect capacitive accelerometers (MEMS) in Sirius HD-LV?
Carlos Salanova
Posted on 30.04.2025 08:20
We are trying to connect single-axial capacitive accelerometers (MEMS) by Kistler -> Type 8316A in the Dewesoft Sirius HD-LV.
According to the datasheet, the sensor pinout is:
  • 1- Power,
  • 2- Return
  • 3- N/C
  • 4- Output +
In the dewesoft side:
  • Exc + (1) and Sns + (6). (Power +)
  • Exc - (3) and Sns - (8) (Power -)
  • In + (2)
  • In - (7)
So we connector is done as follows in dsub9
  1. Power
  2. Output +
  3. Return
  4. GND from TEDS
  5. N/C
  6. Power
  7. N/C
  8. Return
  9. TEDS
+ shield connected.
The problem is that we are getting too much noise in the signal (find picture attached)
Any idea??
Rok Kmetič
Posted on 07.05.2025 13:14
Dear Carlos,
thank you for sharing the connection details. I have noticed that you are using a 3-wire sensor. In this case the Pin7 needs to be manually connected to GND.
Please see the picture below:
The missing connection is marked with the bright green colour.
Please let us know if this helped.
Best Regards.
Rok
