external sample rate signal for high speed camera.
gianni Roose
Posted on 03.05.2016 16:54
We are trying out a DS-CAM-600
1) Is it possible to provide an external hardware signal to the sync port as sample rate trigger.?
For example to use an encoder zero-signal on the camera so that a picture is taken every time at the same angle of a rotating cylinder.
This would act as a kind of stroboscope function.
The rotational speed is variable.
We want to have a minimum of stored pictures.
2) Can a dewe 43 use a digital counter input as a sync signal, so that we can vary the sample rate externally ?
Then we could do measurements directly in the angular domain instead of the time domain.
Any suggestions ?
kind regards,
Gianni Roose
signup
for
free
account
