Current Sensor
I have an AC/DC Current Probe and am in search of the wiring configuration for connecting it to a 9-pin connector, preferably with a TEDS Chip included. Does anyone know how to do this?
Dear Kevin,
Could you please let me know which DAQ device you have? Which current probe do you have?
Best regards
@Matic Pevec
Yes. The DAQ device is SIRIUS-i STGM model. The current probe is a GMC Instrument PROSyS AC/DC Current Probe Model CP 30_11.
Dear Kevin,
In the manual, you can find the pinout which can help you with how to connect the probe.
@Matic Pevec
Unfortunately, I am not highly educated on the wiring topic. How do I know which wire from the current is going to go into pin 1 and so on and so forth?
Dear Kevin,
Unfortunately, I cannot find the datasheet of your clamps which will refer to the wiring of the clamp. What we would need is a description of the colors of each wire on your clamps (e.g. red wire-->+ supply; green-->0V; white-->+ Output; black-->- output). This is specific to the clamps, so I would be really grateful if you could send us the datasheet and we will describe how to connect clamps to the sirius.
Best regards
I attached an image of the sheet that comes with the current sensor. is this what you would need?
Dear Kevin,
Thank you for the picture. You should use the following connection.
@Matic Pevec
Thank you! I saw some images of a current sensor with the TEDS chip, but it had resistors connected as well. Would this wiring need any resistors? Also, does the TEDS chip connect the IO to pin 9 and Ground to pin 4?
Dear Kevin,
In general TEDS chip doesn't demand an additional resistor. If you add it instead, it will serve as security for chip and won't affect the operation in case the resistance is not too large. DS-CLAMPS doesn't require an additional resistor for TEDS.
Regarding the wiring you're right, IO to pin9 and GND to pin4.
BR
@Matic Pevec
I have the current sensor wired up properly. Now do you know how I should have the general setup in the DEWESoftX software? This is something I found online, does this look accurate?
Hello Kevin.
Yes you would Measure the voltage from the current sensor.
If I found the right tech specs it will give you 100mV/A so the 1V would be 10A and 3V is you 30A maximum.
Yes, I see that you have the same specs on the picture above. So we come to the conclusion that no more than 3V your clamps will not output.
So the range can be lowered to 10V. Sensitivity is crucial for the right measurement!
Other detail for Current measurement you can find on our WebPage
Best regards Matjaž
@Matjaž Strniša
We are usually working with voltages around 13.5, sometimes getting up to 18V. What current sensor would I need to be able to obtain an output at this voltage range?
Hy Kevin.
Like said above, the output of the Current sensor depends:
- From ranges of the measurement.
- From Sensitivity of sensor you choose.
If you are measuring 1-30A then your clamps are ok and the output voltage doesn't play any role on what is your measuring result.
That's awesome info on the wiring and TEDS chip! Knowing that for the SIRIUS-i STGM and GMC CP 30_11 clamp-
- TEDS doesn't require an extra resistor (though a small one acts as a safety).
- The TEDS chip connects IO to pin 9 and Ground to pin 4 on the 9-pin connector.
- The 100mV/A sensitivity means a 10V range is enough for the 30A clamps.
